leaking gas through carb??
Old Aug 28, 2000 | 08:38 PM
dondiesel8's Avatar
what would cause fuel to leak through the lower vent hose of a carburetor?? I assume it is the needle and seat, but am I right, or what else could it be?? I've noticed a puddle on the ground after letting my four wheeler sit overnight, tonight I shut the fuel off and will see in the morning if it is still leaking. thanks
Old Aug 28, 2000 | 08:39 PM
dondiesel8's Avatar
by the way, this carb is on an 88 blaster, thanks again
Old Aug 28, 2000 | 08:45 PM
Tree Farmer's Avatar
Ain't likely the "needle," dondiesel8; float valve & seat, probably. If it leaks a little overnight; no biggie; just remember to shut off the tank petcock when you park it.
BTW, the leaking gas probably emerges from the dump tube (drain hose) instead of a "vent hose."
Tree Farmer
Old Aug 28, 2000 | 11:43 PM
YaMaRaPtoR's Avatar
its your float valve level. the float is bent, i dont remember but bend it very little one way or another and try it, i saw somewhere how to maybe in tech connection.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
