Cant pull my axle all the way through
Old Oct 8, 2004 | 06:15 PM
Stoppie's Avatar
Default Cant pull my axle all the way through
Im replacing my bearings and I cant get the axle to come out. It moed a few inches and has stopped. I cant push it back through either. Its just stuck! Any ideas?
Old Oct 8, 2004 | 06:20 PM
Raptor4stroker's Avatar
Get some wd-40 and a piece of wood. Lube the axle with the lube (both sides) and put the wood on the end of the axle (hub) and hammer back into place and then lube again and then hammer it out. You may have to do this a couple of times until the axle gets lube all the way through.
Old Oct 8, 2004 | 11:37 PM
Blastermaster's Avatar
on mine, i just put a cheap 22mm socket on the nut on the end of the axel, and beat the hell out of it till it came out.
Old Oct 8, 2004 | 11:40 PM
Jibrille's Avatar
Thats what I did when I worked on a 300ex
Old Oct 9, 2004 | 01:26 PM
Stoppie's Avatar
Wouldnt it still mess up the treads or the end though?
Old Oct 9, 2004 | 01:54 PM
Raptorboy4life's Avatar
No. I just replaced my bearings. (i was in the same situation) If i were you I would put a socket on that wouldn't touch the threads of the axle and hit it with a sledge hammer. The axle wont get damaged if anything it might knock the bearings in the carrier a little loose so you can get them out easier. and P.S. good luck with the bearings if you need help or dont know how to do it put the carrier in a vice and pound away!!!
Old Oct 9, 2004 | 02:21 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
use a block of wood and hold it on the end of the axle,,,,and hit the wood with a small sledge
be sure to protect the threads
Old Oct 9, 2004 | 02:23 PM
Stoppie's Avatar
I tried a block of wood and the axle just gets stuck in it.
Old Oct 9, 2004 | 07:16 PM
Originally posted by: Blastermasteron mine, i just put a cheap 22mm socket on the nut on the end of the axel, and beat the hell out of it till it came out.
the reason i used a 22 is that is the size of the nut that holds the hub on (if i remeber correctly but its been awhile and my bike is miles away right now) just run the nut down as far as it will go and whale on it. (i left the hub on)
Old Oct 9, 2004 | 08:39 PM
Stoppie's Avatar
Well I went with the socket idea and it worked. Man did I have to beat the hell out of it though. Thanks for the help guys.[img]i/expressions/face-icon-small-cool.gif[/img]
Cantbuytime
Aug 16, 2015 09:13 PM
DeFox500
Aug 14, 2015 05:59 PM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
Rider252
Jul 6, 2015 03:37 PM
