01 banshee clutch problem
Old Oct 18, 2004 | 05:20 PM
RebelPuz's Avatar
Default 01 banshee clutch problem
ok my frriend has an 01 banshee well the problem is is the clutch just stop working we were ridsing one day then half way thru when he went to go he put in his clutch and shifted and went to start out but it just "jumped" the clutch doesnt do anything any more and when u pull the clutch in there is no pressure on it the cable isnt snapped and it is connected at the bottom u can even push the peice were the cable connects to u can push it with ur finger without even puttin almost any pressure on it can any1 help me and him?>???
Old Oct 18, 2004 | 07:53 PM
badcompanyracing's Avatar
I'm thinkin broke plates.
Old Oct 18, 2004 | 09:41 PM
WheelieKing's Avatar
either your clutch arm is bad, or the shaft that disangauges the clutch has mushroomed over. The same thing happend to my 01 banshee. If the shaft is mushroomed over it will be a bitch to replace, you will have to either spilt the cases to slide it out or use a dremmel tool the grind it enough to slide it out the right side. If you do grind it out make sure you flush all of the metal shaving outs really good and change the oil like 7 times after lettin it warm up. tell me what you find out.
Old Oct 19, 2004 | 03:24 AM
Sandfox24's Avatar
Try this,
Locate the spot the clutch cable is connected at the motor (the one you pushed with no pressure). There is a point on the tip of it. There is also an arrow on the case pointing back. It needs to get tight when they line up.
Take the clutch cover off. Inspect for damage.
In the very middle of the clutch there is a screw with a nut around it. Loosen the nut but tighten the screw until the two arrows line up at the clutch cable spot.
That screw could already be loose and fell out. If so there is a small ball bearing that goes behind it, make sure it is still there.
I wouldn't run the bike.
Old Oct 19, 2004 | 09:34 PM
RebelPuz's Avatar
how do i get into the clutch basket and such im only use to dirtbikes and dont no how to get into quades and such i think i need to tear apart everything out of the side were the kick starter is??? right or wrong lmk please..
and thanks for the fast replys to every1 i really appreciate it
skinnyr6
Aug 25, 2023 02:18 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Jul 7, 2015 11:00 PM
