help with warrior
Old Oct 26, 2004 | 09:05 PM
titty's Avatar
Default help with warrior
87-89 warrior while idleing header glowsdull red ticking in head i took off header pipe replaced it but didnot put in gasket when i give it throttle it dies but starts back up and idles is it timming or valves or is it carb please help
Old Oct 26, 2004 | 09:08 PM
maddog56's Avatar
Sounds like your jetting is way lean and your valves need adjustment.
Old Oct 27, 2004 | 11:55 AM
terd's Avatar
BURN IT!!!
Old Oct 27, 2004 | 12:25 PM
NLWarrior01's Avatar
By not putting the header gasket back on you may also be leaning out there too due to exhausting faster.
Old Oct 27, 2004 | 02:18 PM
oldyeller's Avatar
You are either extremely lean or your exhaust may be plugged up.The only other thing I can think of is the engine is over heating.Does it have enough oil?Your not letting it sit still while running for very long periods?It is air cooled so its meant to be moving.It could also be the timing if its out of adjustment.I'd get it checked out before you burn up the exhaust valve or piston.
Old Oct 28, 2004 | 03:34 PM
KILLEREX's Avatar
do you have a nice titty atleast since you only have one??? I am assuming you only have one because your id titty is single form
Old Oct 29, 2004 | 10:02 AM
terd's Avatar
his woman has BIG.....UUUUNS!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 29, 2004 | 05:04 PM
KILLEREX's Avatar
oh, i thought titty was a woman if titty is a man he should have used the id hog-n-b@lls
Old Oct 29, 2004 | 05:06 PM
KILLEREX's Avatar
your quad ran like that because it had 1/2 in. of intake valve clear!!ance
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
