proper banshee compression test?
Old Oct 28, 2004 | 03:03 AM
  #21
DaBeechMan's Avatar
Default proper banshee compression test?
an 18cc dome will change your compression from stock
Old Oct 28, 2004 | 03:04 AM
  #22
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Believe the Beech you wanna be at as high of compression as you can handle and still run premium pump gass so you can affford to ride it still.
Old Oct 28, 2004 | 03:07 AM
  #23
DaBeechMan's Avatar
higher compression wont effect your reliability. It will give you more down low power and i think you would be very happy with that minor change.
  #24
Monkey Rider
Afro-Engineer
Approximate Cranking Compression
These pressures are estimates based on fresh stock bore, piston, porting, and deck height.
It is recommended to check your compression after installation.
Sea Level 1000' 2000' 3000' 4000' 5000'
18cc 238 229 221 213 205 198
19cc 211 203 196 189 182 175
20cc 184 177 171 165 158 153
21cc 157 151 146 140 136 130
stock 130 125 120 116 112 107
Old Oct 28, 2004 | 10:00 AM
  #25
sAyIt_fmf's Avatar
115psi in a banshee is very weak. Your motor should read at least 160
I agree and disagree at the same time. 120 psi for a banshee will be just fine. It will still scare the crap out of you. Plus I think you will find that if you end up freshening the top end. You will end up with more like 135 in each cylinder.
I am not a big fan of shaving heads...run an aftermarket head if you feel that the compression needs to be 160 or up.
If your going all out with the motor. Then I would say to get the highest amount of compression possible. From the sounds of things..you just plain want a good, ridable bike. Freshen the top end and be done with it for around $200.
Old Oct 28, 2004 | 06:08 PM
  #26
DaBeechMan's Avatar
stock heads are fine.
Do you even know what compression does for a motor?
Yeah i can build a banshee with 100psi in each cylinder. That bastard would run hard on the top end and "scare the crap out of you." Or i can build a motor with 170 in each cylinder and that same motor would walk away from you.
Old Oct 28, 2004 | 06:22 PM
  #27
Monkey Rider
Afro-Engineer
Compression = tourque!!!!!!!!!!!!!!!! ohh yeah. ever notice the harder you throw a superball at a wall (compresses) the harder it rebounds back at you?
Old Oct 28, 2004 | 06:33 PM
  #28
DaBeechMan's Avatar
hm...torque=horsepower.
COWBOY WE ARE ON TO SOMETHING HERE!!!!
Old Oct 28, 2004 | 06:44 PM
  #29
Monkey Rider
Afro-Engineer
OOHH OHHH LET ME GUESS!, LET ME GUESS
More Compression = More Tourque = More Hp = More Acceleration [img]i/expressions/face-icon-small-shocked.gif[/img] OH OH thats if you got the right traction [img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 28, 2004 | 06:58 PM
  #30
DaBeechMan's Avatar
quick, lets take advantage of all the idiots out there and manufacture 15cc domes! MORE COMPRESSION=MORE POWER!
oh crap...15cc domes already exist...
lol i crack myself up sometimes
