kodiak 450 -fuel
Old Nov 4, 2004 | 11:22 PM
  #21
zsebi's Avatar
Default kodiak 450 -fuel
there is nothing wrong with a mechanical gauge, the more simple the better,
you don't even need to have ignition turned on to tell wether your ATV is filled with gas or not. example when the ATV is on the trailer and you may be towing it somewhere.
I did some checking today,
my gas gauge shows empty. looked through the gas tank filler (with a flash light [img]i/expressions/face-icon-small-smile.gif[/img] ) and there is lots of fuel in the gas tank, more than a gallon for sure (reserve). however I have noticed that the fuel petcock (which has 2 plastic drain tube wich also act as a filter ) one higher plastic tube , this would drain when it is switched to the ON position, and the fuel level right now is just barely above and would have to switch to reserve very soon.
the lower tube (which is for reserve ) drains all the fuel , but as I said it iseems that there is a lot more than a gallon left in the tank.
I will fill it to the top tomorrow and see how much fuel it takes since the gauge shows empty.
Old Nov 5, 2004 | 09:15 AM
  #22
DougMd's Avatar
.....so are we to believe that the tank gauge is for the upper tank, that AFTER hitting "E" we'll still have more than a gallon left of gas about when we have to switch to reserve? Seems to me that if that's the case, we are in good shape, because a gallon gives us plenty of time at that point to get gas, and can be treated as a 'warning light" as with regular automobiles.
Old Nov 5, 2004 | 12:27 PM
  #23
MiseryMachine's Avatar
yeah, if it reads Empty, that means your 15L side of te tank is empty, leaving you with a 5L Reserve...
Old Nov 5, 2004 | 04:26 PM
  #24
zsebi's Avatar
the gauge was on dead empty ,but did not have to switch to reserve yet,
went to fill it at the gas station, 2.6 gallon to the top of the tank ,
If I am correct we have a 4 gallon capacity , which leaves us with 1.4 gallon once the gauge shows empty.
Old Nov 5, 2004 | 10:13 PM
  #25
i believe it is a 5 gallon tank... 20L is 5 gallons up here... i know you guys are a little different... but not that much..
Old Nov 6, 2004 | 12:29 PM
  #26
zsebi's Avatar
no,
looking at the 05 ATV yamaha print out
grizzly 5.3 gallon
kodiak 4
bruin350 3.8
bruin 2503.2
big bear 4 gallon
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
