"Wolverine Tires"
Old Nov 6, 2004 | 10:16 PM
  #31
BigBaller's Avatar
Default "Wolverine Tires"
RIGHT BEHIND YOU LOTUSPOSITION!!!!!
04 Honda Rubicon
03 Kawasaki Prairie
01 Yamaha Wolverine
modded and not to 44 mph!
Old Nov 6, 2004 | 10:20 PM
  #32
elkbow's Avatar
Originally posted by: BigBaller
A wolverine at 44 mph! ahah you must have that Bo*t Leg yaNaha instead of the Yamaha. a YAMAHA wolverine would hit 55 NO PROBLEM! put a nice pipe on it an air filter and you got your self some speed . 44 mph? LMAO
at 350 engine at 55 mph or 58 mph....ok, i want you to do what we did and then take a picture of it and post it on here.....put your GPS on your machine, make sure you are locked on to a good amount of satellites, and then run full throttle on flat land....
granted, we were running at about 5500 feet elevation here in New Mexico, but we topped out at 44 on one machine and 43 on the other....we then took a friends Big Bear and run it to 36 mph.....
don't think what you read on your speedo is correct, most are way off....I bury my speedo on my 700 EFI, but the fast I had it on the GPS was 68 mph....
I'm not slamming the Wolverine, I think it is one of the best all-around Utility ATV's out there... Here at elevation from 5000-13000 feet, you're not going to see the performance that the magazine review did when they speed checked a Wolverine at sea-level and on a paved road when they clocked it at 58 mph, which they also later stated that it was higher than they expected and could not duplicated that speed with other machines. If we weren't running at such high altititude and he didn't beat the crap out of his machines, I'm sure we could have reached over 50 mph, which is amazing for a 350 motor. Still, the subject is getting the tires to wobble at speed, which mine wobble at 40+, but hard to tell until I reach over 50. At 40-50, it just feels like the front end is floating. At 50+ I can feel the wobble. However, it doesn't get any worse, just a slight wobble.....at higher speeds the front end on all ATVs is light and they drift on dry dirt roads that are mostly sand...
Old Nov 6, 2004 | 10:23 PM
  #33
elkbow's Avatar
Originally posted by: LotusPosition
If your friends 2 wolverines only run 44MPH, he had better find someone that knows how to fix them so they run right.
If you think mine is a freak or I am a liar, do a search on Wolverine top speed on this forum. There are many, many threads to back me up.
post a picture of a Wolverine speed from a GPS or a speed gun....read my last post....I think it is a great machine, but because someone posts that the speed was measured at 58mph (magazine review), that does't mean that they will all hit that speed....i'm not talking about running on pavement and sea-level here....I bet I can get my 700 up to 75+ mph, I've read that before, i don't necessarily believe it, but under the right conditions, altitude and pavement, it might make it...hell, i can probably get over 80 going downhill, maybe 85+ out of an airplane...lol
Old Nov 6, 2004 | 10:25 PM
  #34
elkbow's Avatar
04 Honda Rubicon
03 Kawasaki Prairie
01 Yamaha Wolverine
look where all of you guys are from, flatlanders, your highest elevation doesn't meet our lowest...
Old Nov 6, 2004 | 10:26 PM
  #35
BigBaller's Avatar
I cant find you proof because i dont have a speedometer for my wolverine but me and my brother take my RUBICON which has a speedometer and my wolverine out on the streets for a ride here and there. THE RUBICON TOP SPEEDS AT ABOUT 50 MPH! im wayyyyy Ahead of him with the wolverine so atleast 55 on a wolverine. Im sure some one will show you that speed on a wolverine. 350cc engine SAME ENGINE AS YAMAHA 350 Raptor and SAME ENGINE AS 350 WARRIOR. only about 100 pounds more then both of them. So that would make it go about 7-10 mph slower and the 350 rapo can hit speeds of 65 almost 70 so there for the wolverine can deffinatley do 55
Old Nov 6, 2004 | 10:32 PM
  #36
LotusPosition's Avatar
If you are too lazy to use the search feature to disprove me, that is your problem, not mine. There are plenty of Wolverine owners on here who will agree with my top speed assessments.
I don't ride at 5500 feet, but probably would be smart enough to rejet if I did.
Old Nov 6, 2004 | 10:33 PM
  #37
elkbow's Avatar
aahhh, no speedo, thats right, there is no speedo???? so how did we get the speeds?
anyways, like I said before, the Wolverine is a great machine, If I could find one at a good price, I'd pick it up to have a second machine for others to ride on. We had two of them up elk hunting this year....the motor and light weight were the two biggest advantages that I noticed, the full time 4WD was the only downfall...
Old Nov 6, 2004 | 10:35 PM
  #38
I have a factory speedo, and have been clocked by my friend's Polaris on numerous occasions.
Old Nov 6, 2004 | 10:36 PM
  #39
elkbow's Avatar
hmmm, rejet? are machines are already setup from the dealer with correct jetting, couldn't sell them without it, they come from the factory that way, but in New Mexico you can get all the way down to probably around 2-3000 feet and then ride up to 13000 feet, not much you can do there but what I did on my 500....install a dial-a-jet....
Old Nov 6, 2004 | 10:39 PM
  #40
BigBaller's Avatar
I KNOW MAN JUST SEARCH ON A SEARCHING SIGHT LIKE YAHOO.COM. YAMAHA WOLVERINE TOP SPEED. Im sure you will find the right speed of a wolverine.
