figured it out
Old Nov 7, 2004 | 01:02 AM
warwgn's Avatar
Default figured it out
turns out that my plug cap was the only bad part, took alot off messing around and finally setting the ohm meeter right(DUH). This was found after I borrowed a 2001 cdi and coil to see if it would start, which it didnt, and the 01 cdi blew up my starter relay. Then after all the testing I put my 02 cdi back on and then jumped the leads across the relay and it fired right up, then tested the relay and sure enough it was bad now!!!!!! I was told by Patsraptor that a 01 cdi would not work, I should have listened, but the guy I borrowed it from says his is a 2001 with a 2002 motor, and his runs fine, guess that has to do with the harness or something who knows. All I know is now I need a starter relay!!!
wrencher82
Sep 28, 2015 10:02 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
dakotah
Sep 26, 2015 04:25 PM
wrencher82
Sep 24, 2015 03:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
