Can a dying or dead battery cause your quad to idle / run bad?
Old Nov 7, 2004 | 01:13 PM
deltadawg's Avatar
Default Can a dying or dead battery cause your quad to idle / run bad?
Just wondering because I think my battery is dying. It drops to around 6 volts dc when I hit the start button. Then after I get it running it idles funny....WTF/?? Need some expert advice..Thanks
Old Nov 7, 2004 | 04:21 PM
ZillaRider87's Avatar
it shouldnt affect the idling or running of the quad. its like on a car if you get it jumped cuz battery is dead, the car runs fine
Old Nov 7, 2004 | 06:02 PM
Raptorboy4life's Avatar
Charge it!... try putting it on the charger and then starting it and you will get your answer.. im positive it wont affect your idle but its good to try..
Old Nov 7, 2004 | 06:07 PM
hondabuster's Avatar
If you keep the voltmeter hooked up....after it starts, does it get to at least 12.8 volts? If you rev it to about 5000 rpm, does it get to 14. volts? If it does, then the battery isnt effecting the idle.
If a battery drops to below 10 volts while cranking...its on the way out. Have an auto parts store, do a load test on it.
Old Nov 7, 2004 | 06:29 PM
Doctorturbo's Avatar
GOT BOOST!
Yep, it sure can.
Old Nov 7, 2004 | 06:54 PM
deltadawg's Avatar
YA, IT DROPS TO ABOUT 6 VOLTS.........DOH[img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img] IT ONLY LASTED ME 2 YEARS THAT POS.
Old Nov 7, 2004 | 07:29 PM
500zuki's Avatar
no-all the battery is for is to run the starter. My LT500 dosen't have a battery and idles just fine. lol
Old Nov 7, 2004 | 08:28 PM
deltadawg's Avatar
Ok dang it...found the idle problem....The dam choke spring has rusted and was stuck open. Made sense, as soon as the engine was warm it started running like shii1iiiit, then I would give it a little gas it would make a flood out sound and die. [img]i/expressions/face-icon-small-mad.gif[/img] Ok check my next post.
Old Nov 7, 2004 | 08:57 PM
lol[img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 8, 2004 | 01:21 AM
That lt500 had a magneto ignition, almost all others have a battery/cdi/coil ignition...and they do need a battery to run.
