1997 blaster help needed
Old Nov 18, 2004 | 08:37 PM
kdrifter440's Avatar
Default 1997 blaster help needed
I JUST BOUGHT A 1997 BLASTER FOR CHEAP. THERE IS NO SPARK. WHEN I HOOK A VOLTAGE METER UP TO THE PLUG I GET negitive 1000 DC ??. WHAT DO YOU GUYS THINK IT COULD BE??? does someone one here have a wiring diagram?
Old Nov 18, 2004 | 10:08 PM
yamahawarriormods's Avatar
wish i could help ya search diagrams for blaster at google i have luck with that before
Old Nov 19, 2004 | 01:58 PM
potentpete's Avatar
you can't measure the voltage at the spark plug, it doesn't work that way, here is what you want to do, unplug the harness coming from the stator, set your ohm meter to 2000 ohms, touch one lead to the black/w red tracer wire going to the stator and the other to ground, you should have a reading of about 228 ohms, if it is less, then your stator coil is shot.
Old Nov 19, 2004 | 04:54 PM
Shav0's Avatar
Just sticking it in the spark plug cap won't do anything. Do like pete said and see what you get for results. Alot of times on older blasters the coil wears out causing no spark. But luckly they are cheep to fix.
Old Nov 19, 2004 | 05:52 PM
I get 168 ohms from the stator does that mean its the problem for sure?
Old Nov 19, 2004 | 06:56 PM
Shav0's Avatar
Defently. You want it to be at least 220-230.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Mphillips
Jul 2, 2015 07:20 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
Djinn
Aug 31, 1999 10:36 PM
