how can i tell if my motor is ported
Just knocking the carbon off I am sure you didn't open them up too much. For trail riding, I cut open the exhaust port by 2mm upward. Surely you didn't grind that much.
Measure from the very top of the exhaust port to the top of the cylinder deck. If its 30mm, its not ported.
Originally posted by: AlkyBurninX
15HP if you also widen the exhaust and open the other ports up. You don't want to do this unless you have an idea about porting. If you raise it 2mm without widen and shaping the port, it will make a narrow peaky powerband.
