How to fix cracked fender??
Old Dec 5, 2004 | 11:31 AM
Kevjenty's Avatar
Default How to fix cracked fender??
I have a 8 inch crack on my Bear Tracker fender- What's the best way to repair?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 5, 2004 | 12:12 PM
Raptorboy4life's Avatar
Zip- Ties... Sew it!!!!! lol... They also have plastic wekding kits!!!!!!!! and they do work just ta let ya kno
Old Dec 5, 2004 | 12:29 PM
blindside350's Avatar
Its true, that have plastic welding kits for alot of plastic colors. But afterword you'll have a big line and can tell it was cracked. But its better than buying new fenders!
Old Dec 5, 2004 | 01:16 PM
warrior68man's Avatar
You can do it the old fashion way.
Drill holes around it and zip tye.
Plastic Welder for 35 bucks.
www.rockymountainatv.com
Under the Tools Section.
Another thing I found works good is to drill holes on each side of the crack.
Get a piece of aluminum that covers the crack.
Put it underneath your fender and redrill the holes you drilled in your plastic in the same spot on the aluminum.
Trim the aluminum so it doesn't stick out.
Shoot rivets in the holes and then you can paint the rivets if you want but that will keep the crack together.
Old Dec 5, 2004 | 03:12 PM
Magyver's Avatar
the quick fix warrior68man implied, works good. I have used that method many times,
Will last a while also.
I like the plastic welder idea the best though. [img]i/expressions/face-icon-small-wink.gif[/img]
peace
Magyver
fd24
Jan 16, 2019 08:59 AM
franklyme
Oct 21, 2016 07:18 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
89Lt250r
Sep 7, 2015 07:53 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
