!!!Stalling Wolvey!!!
Old Dec 18, 2004 | 01:25 AM
Daranello75's Avatar
Default !!!Stalling Wolvey!!!
Tonight I was doing donuts on my wolvering in just below freezing weather and the motor loses all power after the 2 or 3 donut in a row!!!! This problem only happends during donuts. Thank you in advance for your help
Old Dec 18, 2004 | 02:00 AM
someone please help me
Old Dec 18, 2004 | 02:23 AM
Doctorturbo's Avatar
GOT BOOST!
Sounds like a low float level to me. Could also be a clogged tank or carb vent.
Old Dec 18, 2004 | 02:26 AM
Whats a "low Float"? and how cant I fix that?
Old Dec 18, 2004 | 02:48 AM
GOT BOOST!
A float is a device that controls the valve that lets fuel into a carburetor. If it is low, it won't let enough fuel into the carb and the engine will run out of gas when the gas sloshes away from the jet in a turn. (In your case a donut)
For pictures and good tips go here. Here
Old Dec 18, 2004 | 09:16 AM
ChadW's Avatar
Mine is doing the same thing. I have had nothing but carb problems with this thing. I think what happens is there is crap in the carb from the horrible airbox design and when you do a couple of hard donuts it rises off the bottom of the carb and clogs the main jet. This is only a theory and I need to clean the carb again and find out.
Old Dec 18, 2004 | 05:19 PM
86LT250RFatty's Avatar
heres a tip. When you clean out your carb, go to the hardware store and for 5$ you can get a hi-flow fuel filter, just snip you fuel line and throw it in their. then you wont get so much crap in it. i think its a low float level too, i do dougnuts alot on my rappy and it doesnt seem to lose any power.. just rubber...
Old Jan 4, 2005 | 03:31 PM
A float is a device that controls the valve that lets fuel into a carburetor. If it is low, it won't let enough fuel into the carb and the engine will run out of gas when the gas sloshes away from the jet in a turn. (In your case a donut)For pictures and good tips go here. Here
How do I fix the Low Float?
Old Jan 4, 2005 | 03:53 PM
well rich...(ur rich...) to adjust the float level you have to take the bottem of the carb off, and then their will be two flaps which controll the level of the floats, the floats or two black like, ***** that float on top of the gas. Bend these tabs slightly up, allowing the floats to sit higher....i will look to find some pic's because its hard to explain.
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
