Hard throttle
Old Dec 23, 2004 | 03:54 AM
ZEEpusher's Avatar
Default Hard throttle
Got an 88 Warrior from the original owner. I've always had to adjust the thumb trottles on each quad I get. I couldn't find a place where my thumb wouldn't get sore or numb after 10 minutes of riding. Last trip out we stopped a couple of times, moved it up, nope. Moved it back. Nope. made sure there was a nice curve in it and free of kinks. Then a friend borrowed it and it killed his thumb too, and he swings hammers all day. I'm NOT switching to a twist. I just don't like them. Everybody already suggested that. The guy I bougt it from said it NEVER had a new one put on. Should I replace the cable and housing? Or would it be easier to take it off and spray it down with penetrating oil? I think it has barrels on both ends, so I don't think I could just pull the cable out and clean it out.
Also is there places in the lever it self that I can do something to make it easier?
Has anyone had this problem before? If so what was the best fix? I'd like to do it right the first time, even if it means new trottle lever assembly, cable and housing. Unless there's somethng I'm missing.
BTW we ruled out lever extenders. That thing is just TIGHT.
Thanks in advance for any help.
Old Dec 23, 2004 | 05:11 AM
VelociRaptor350's Avatar
They sell a cable lube kit, it lets you shoot cable lubricant into the cable itself. Tusk makes a kit, its part number: 19-6011 on rockymountainatv.com, its only 12 bucks so its worth a try.
Old Dec 24, 2004 | 12:53 PM
YFZ450kid's Avatar
just replace the cable, i had a similar problem with my 89 warrior. I found it to be better to just switch to a twist throttle anyway. I bought it with a thumb but i think warriors have heavy springs in their carb because they are built bullet proof.
Old Dec 24, 2004 | 01:34 PM
2FAST4URASS's Avatar
I had a timberwolf back in 96 i did alot of mud rideing and started to have that problem tryed the lube it was a no go!!! so i got 5 gallon bucket and bought a cheap quart of motor oil dumped it in the bucket rolled the cable and put it down in the oil left it over night got up pulled her out wiped it down put it on worked like new [img]i/expressions/face-icon-small-wink.gif[/img]
Cummins Driver
Sep 11, 2019 01:22 PM
GregM
Mar 6, 2018 06:53 AM
Jazperman
Aug 7, 2016 08:12 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Ashley S
Aug 6, 2015 12:56 PM
