sprocket help
Old Dec 30, 2004 | 11:53 AM
fastblaster00's Avatar
Default sprocket help
how many mph would i gain if i put a 14 tooth front sproket on, and how much low end speed would i loose. i have a full pipe jet kit k&n air filter no air box lid and 20 inch rear tires. would i be better off getting a 42 tooth rear instead. i want more top end but i dont want to loose my exceleration. i need to replace both sprockets and the chain anyway so eaither way im buying new ones. please help me
thanks
jeff
Old Dec 30, 2004 | 12:22 PM
ZillaRider87's Avatar
thanks
jeff
you cant mix n match so you gain speed but not power, your going to have to sacrifice one when you gain the other by gearing changes. a bump up on the sprocket adds maybe 4 mph to the top speed. you will have a little noticable loss in power though.
Old Dec 30, 2004 | 12:24 PM
VelociRaptor350's Avatar
RMATV.com has a closeout special on titax front sprokets, they are 9.99, i picked up a 12 tooth just to try it out.
Old Dec 30, 2004 | 12:31 PM
yea, fronts are alot cheaper too. if you try to keep messing around and buying new rears, youll be out of alot of money, those run i think 42 bucks.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
