NEED HELP WITH WHINCH
Old Dec 30, 2004 | 11:05 PM
BigBaller's Avatar
Default NEED HELP WITH WHINCH
I have a superwhinch 1500 and yesterday me and my uncle went for a ride. He got his 360 prairie stuck and then dug him self in deeper. When we attachted the whinch to his quad and I started realing him in and driving back, MY WHINCH BROKE! My clip that is attached to the wire broke. I am wondering if I did anything wrong to whinch him out and what is the proper way to whinch some out?
Old Dec 30, 2004 | 11:08 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
isn't it.. wrap the cable around a secure point and attached it to the line..? or use a tow strap? hhmm... iom new to winches.. am thinknig of investing in one if i start riding in southern IN more.. so ill need to know also..
Old Dec 30, 2004 | 11:09 PM
Speedy2222's Avatar
where did it break?? did it just break at the end?? did it bend it any?? also what did the cable do when it snapped?
Old Dec 30, 2004 | 11:11 PM
BigBaller's Avatar
They are really a great thing but my uncle put it on his quad the wrong way. When I get stuck I usualy tie it around a tree and attach the clip to the wire, so it snugs the tree nice and tight.
Old Dec 30, 2004 | 11:12 PM
BigBaller's Avatar
Well do you know how it has a clip on it? Well my uncle put that around a small hole in his bumper. I heard that you should put a weight of some sort on it just incase the cable snaps god forbid it jumps up and hits you.
Old Dec 30, 2004 | 11:13 PM
Speedy2222's Avatar
i heard a towel or soemthing.. so if it snaps it don't hit you... o man.. so much controversy on proper ways to winch..
Old Dec 30, 2004 | 11:16 PM
BigBaller's Avatar
I once went to a atv park in pennsylvania and I had to watch a video and it showed that if you are whinching you need a tree saver or sumthing like that lol if you want to whinch ur self out from a tree. Anything heavy will work so the cable doesnt hit you.
Old Dec 31, 2004 | 03:05 AM
confusedbuyer's Avatar
you said you went to pull him out, by driving the quad? I usually get my quad anchored against a tree stump or big rock. free-wheel the line to the stuck quad. then i use the WINCH to pull, not the quad. i loop the cable around and thru the hook. OR, you can double your winch pull by using a pulley block, which shortens the cable by half, but doubles the line pull.
a blanket draped over the cable during pull will cause snapped cable to do less damage.
Gtchy1230
Apr 29, 2011 09:09 AM
speedyman12345
Nov 26, 2006 12:12 AM
BigBaller
Utility ATVs
Jan 25, 2005 05:25 PM
BigBaller
Jan 11, 2005 09:13 PM
vernl
Jan 7, 2001 08:13 PM
