Warrior wont turn over! help please!
Old Jan 2, 2005 | 01:43 AM
Rem's Avatar
Rem
Default Warrior wont turn over! help please!
so by turning over you mean starting? because usually when someone says it wont turn over it means its siezed
Old Jan 2, 2005 | 07:42 AM
blasterrider's Avatar
try turning the fuel half way on you might be getting to muchy fuel or your battery is low on juice
Old Jan 2, 2005 | 11:12 AM
WolverineMan15666's Avatar
Try to catch start it. Have someone pull you. If it starts it may be your stator again.
Old Jan 2, 2005 | 11:51 AM
7QuadSport7's Avatar
how do u catch start???
Old Jan 2, 2005 | 12:09 PM
  #15
fastblaster00's Avatar
this sounds stupid but do you have gas in it. try putting the fule on reserve. like wolverine man said try push starting it. you could also spray some starter fluid into it and see if it starts. good luck
Old Jan 2, 2005 | 01:58 PM
  #16
To catch it, Either drift it or have someone tow you.
1. Turn the key on
2. Put the Warrior in 6th gear
3. Pull in the clutch
4. Start drifting down a hill or have someone pull you with a tow rope
5. When you get up some speed let the clutch out and maybe give it some throttle.
It should start. If it starts this way, the stator may be bad. The stators went bad on a few different Warriors that I know.
Old Jan 2, 2005 | 02:04 PM
  #17
On the Warriors that had bad stators, they would turn over but would not start. If you would push or catch start it it would start and run fine until you shut it off. My buddy use to carry a long tow rope for a couple months, so his buddies could pull him to start it. He finally got a new stator.
Old Jan 2, 2005 | 02:07 PM
  #18
I read that you just replaced the stator. THAT'S THE PROBLEM it's the stator. IT"S THE STATOR.
Old Jan 2, 2005 | 02:13 PM
  #19
do it in 6th gear. thats wayyyyyyyyy to high of a gear. 2nd or 3rd at the most. 1st is to low. i do my warrior in 2nd
Old Jan 2, 2005 | 02:45 PM
  #20
NJatvRider96's Avatar
if i just replaced the stator how can the stator be the problem?? its brand new.
