12.5:1 compression and alcohol
Old Jan 1, 2005 | 02:15 AM
duneittilludie's Avatar
Default 12.5:1 compression and alcohol
I have a 690 raptor with 12.5:1 compression and porting and and i cant find specific information on wether or not i can get a good performance gain if i switch to alcohol from gas ,any input?
Old Jan 1, 2005 | 04:31 AM
Rem's Avatar
Rem
riding and alcohol never mix...
Old Jan 1, 2005 | 12:22 PM
Bradracer18's Avatar
From what I understand you'll have to mix race gas(110) with some premium gas(91-92)............
Old Jan 1, 2005 | 12:36 PM
86LT250RFatty's Avatar
I agree, 50/50
Old Jan 1, 2005 | 12:42 PM
I guess that i didnt make myself too clear because what i am wanting to know is what gains could i see when (switching) from gas to alcohol and what effect if any would compression have on doing so.
Old Jan 1, 2005 | 02:10 PM
Doctorturbo's Avatar
GOT BOOST!
I can't give you any numbers but in general you will pick up quite a bit torque and some power. The hotter the weather the more advantage you will have over the gas guys. In real hot weather you will have a big advantage over gas.
Old Jan 1, 2005 | 07:03 PM
NJRaptor419's Avatar
be sure you check into the maintenance before turning your raptor into an alchoholic. I believe your mileage goes down considerably also.
Old Jan 2, 2005 | 07:50 AM
bad350twin's Avatar
i have ran both and i noticed a big gain in the top end..... the only hassle is weather changes (jetting) and having to purge with gas after your done riding at the end of the day!
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
