Hole in exhaust...help!!!
Old 01-02-2005, 10:25 PM
cwinter's Avatar
Default Hole in exhaust...help!!!
2001 Warrior with a full DG Chrome exhaust system.
The rear mounting bracket cracked completely off. Now there's a hole the size of a small dougnut in my exhaust.
What can I do...besides the obvious "buy a new one"???
Old 01-02-2005, 10:36 PM
catchmeifucan's Avatar
could have a piece af sheet metal welded on with the bracket. It would work just the same.
Old 01-02-2005, 10:49 PM
FdaDOT200's Avatar
its cause its a DG, but an HMF or Yoshi or T4.
Old 01-02-2005, 10:53 PM
Vinson581's Avatar
you could tack weld a piece of metal over it
btw- DG chrome pipes are really junky built, same with there 2 stroke pipes,
i agree get a pc T4, yoshi, or a HMF you wont have the problem, plus you will pick up some more power!..
v581
Old 01-02-2005, 11:47 PM
YFZ450kid's Avatar
get a welder and fill the hole, its not rocket science, or get some duct tape that sh#$ fixes everything
Old 01-03-2005, 09:37 AM
D3athShad0w's Avatar
Get a better pipe like a T-4 or a White Brothers, they work great with warriors!! When I first got my warrior I had put a crappy Cobra pipe on; the mounting bracket broke due to shock and hard riding, its really just because the mounting method they use sucks... T-4s use a grommet and spacer method of mounting to absorb shock and impact so it wont break; the pipe is GREAT!
Old 01-03-2005, 12:45 PM
cwinter's Avatar
I think I'm going to go with the White Brothers E Series pipe.
I won't be buying it until the spring...so in the meantime can I do a quick hack job on my busted muffler???
Maybe some tin and some metal straps???
Any ideas????
Old 01-03-2005, 01:01 PM
weld away X_X
franklyme
10-21-2016 07:18 PM
Sassinm1
09-30-2015 04:23 AM
2many2ride
09-27-2015 04:35 AM
MikeyBoyesq
09-22-2015 10:02 AM
toonces
09-05-2015 01:14 PM
Quick Reply: Hole in exhaust...help!!!
