Blaster snorkel
Old Jan 4, 2005 | 09:12 PM
Camarothatcould's Avatar
Default Blaster snorkel
Tomorrow I'm going to start making a snorkel for the stock airbox for my Blaster. I'm going to run 2 inch tubing from airbox opening underneath tank and ending it somewhere behind the grill. I'm probably going to throw on a rectangular filter at the end of tubing and ditch the one in box. Has anybody ever tried this or seen it anywhere? I'm doing this because I ride in muddy/rainy conditions. Anybody see any issues I might run into? Thanks
Old Jan 4, 2005 | 09:36 PM
86LT250RFatty's Avatar
you might have to lean out the Main jet a size or two
Old Jan 4, 2005 | 09:49 PM
What size jet should I run? Only mods i have are a pipe.
Old Jan 4, 2005 | 10:08 PM
Rem's Avatar
Rem
i dont think you should do it to the blaster with a pipe, because its going to severely rob your horsepower, but we cant even try to suggest what jets you should try if you cant tell us what u have in now, and if its running lean or rich
Old Jan 4, 2005 | 10:54 PM
fastblaster00's Avatar
id run it under the gas tank cover and have it come up on the handle bars and have the opening face the back of the machine.... i wouldnt wnat it facing the direction that the water is heading in. id run more htan a 2 inch pipe... idk if 2 inches is enought but it seems a lil small for me. id run like 1/2 and inch bigger than the snorkle is. good luck tho
Old Jan 4, 2005 | 10:55 PM
id put a k&n in the box cause it might help flow a lil more air with such a long snorkle.... your probly gona be one of the only people with a snorkel on a blaster. i thought about it but never tryed it. good luck tho
Old Jan 4, 2005 | 10:57 PM
7QuadSport7's Avatar
on a blaster??????????
Old Jan 4, 2005 | 11:37 PM
It's ok, I like to be different. It's only an experiment, the stock snorkel I think is crap so I run without it, so that leaves the box with just the hole which is in a bad place bc lots of mud gets caught up in it, so I figure a snorkel might help. As for the jet, does 240 sound right? I'm going to crack open carb sometime this week to clean it so I'll find out for sure later. thanks for all your opinions.
Old Jan 5, 2005 | 12:01 AM
Rem's Avatar
Rem
youre only running a 240 with a pipe?? what altitude are you at?!?
Customer Service #1
May 15, 2020 08:46 AM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Steeldon
Sep 9, 2015 09:38 AM
Ean
Aug 20, 2015 07:13 AM
