wolverin vibrATION PROBLEM
Old Jan 6, 2005 | 04:34 PM
fudmucker's Avatar
Default wolverin vibrATION PROBLEM
I JUST PUT A BRAND NEW FULL SKID PLATE UNDER MY WOLVY A REAR SKID PLATE AND A A ARM SKID PLATE ON BOTH SIDES IN THE FRONT OF IT. IT SEEMS TO VIBRATE ALOT SINCE I PUT THEM ON I DUNNO IF ITS THE SKID PLATE OR SUMPTHIN ELSE. BUT IF ANYONE HAD THIS SAME PROBLEM I WOULD APPRECIATE IT OF U TOLD ME HOW DO DEAL WITH IT SUMHOW
Old Jan 6, 2005 | 06:08 PM
hondaguy2's Avatar
If it is the skid plate that is making that noise, then go to a local hard ware store and pick up some rubber washers that should solve the problem. Then put the rubber washers betweent the frame and the skid plate.
Old Jan 6, 2005 | 07:05 PM
fudmucker's Avatar
I PUT LOCK TIGHT IN THE BOLTS SO I DUNNO IF ITS GUNNA BE THAT EASY
Old Jan 6, 2005 | 07:32 PM
Wolverine2003's Avatar
As long as you used the blue stuff you'll be able to get the bolts loose. Take it from a guy that uses a LOT of Loctite on 2 Harleys and 2 quads. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jan 6, 2005 | 08:08 PM
fudmucker's Avatar
I HAD THE GREEN STUFF
Old Jan 6, 2005 | 08:15 PM
The green stuff is the "wicking" formula, you'll be able to get the bolts loose. The red stuff is the tough stuff. For normal use the blue formula is the best for when you want it to hold well but be able to get a bolt off when you need to.
Old Jan 6, 2005 | 08:19 PM
fudmucker's Avatar
I DUNNO IF ITS THE SKID PLAT VIBRATING OR NOT ON UR WOLVERIN DO U HAVE ANYTHING THAT VIBRATES ALOT........IT ONLY SEEMS TO HAPEN WEN I REV MY RPMS UP
Old Jan 6, 2005 | 08:26 PM
Yeah, it's kind of "buzzy" in the upper rpm's. I've checked the torque of all the engine bolts, checked the fender mounts and everything else. It's just the nature of the beast.
I went with the Maier plastic skid plate on mine. I had one on my '93 300EX and it took a lot of abuse and held up really well. So far the one on the Wolverine is too. We do a lot of rock crawling and banging over fallen trees. It's really hard to believe the plastic holds up as well as it does.
Old Jan 6, 2005 | 10:38 PM
fudmucker's Avatar
YEAH THE SAME WE DO HERE.... I HAVE A PROBLEM HITTIN ROCKS FOR SUM REASON AND THE WOLVY WAS IS SO LOW TO THE GROUND ITS HARD TO NOT ANY ROX ON A RIDE.... BUT I GOT AN ALUMINUM DG SKID PLATE REAR FULL BOTTOM AND A ARM SKID PLATES
Old Jan 7, 2005 | 12:56 AM
tdragano's Avatar
Another option besides the rubber washers is a piece of bicycle inner tube. I just cut about an 8" piece out of an old tube I had and placed it along the center frame rail. The noise was gone and the tube has never worked itself out. A piece along the outside rails sure wouldn't hurt either.
Firefighter400
Oct 8, 2022 06:38 PM
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Captjay
Jul 23, 2015 12:33 PM
hondarider1234
Jul 21, 2015 11:53 PM
