Suzuki Z400 Vs. Yamaha Warrior
#93
I have a 97 yamaha warrior with aftermarket cluches, an 04 stock full system Exhaust, holeshot XCT front tires 23inch and dirt devel rear 22inch tires, and a weisco piston. I can keep up with a Z400 in the woods no problem. iam about 150 pounds. the Z400 is an 03. its completly stock. i don't have that much into mine, but i can deff. say that a 400 isn't that much more faster than mine. maybe top speed wise but thats about it. i mean, you can only go so fast in trails, so we both are never toped out.
#94
#95
Is the stock Z400 running? does it have a rider? That's about the only ways in which I think a warrior with a pipe is going to beat a Z. You've got some work to do on a warrior just to get to the HP of a Z, then you have the weight difference to contend with, not to mention handling and suspension ..
In short, no.
In short, no.
#97
Originally posted by: motox26
I'm pretty sure a piped blaster will lay down faster times than a stock Warrior. A stock blaster isn't that far behind. At least in my experiences.
#98
hey D3athshad0w learn befor u open ur mouth u dont need to jet anythang it will still run if u dont jet it when u add a new pipe it might run a lil ruff but adjust ur air/fuel mix screw on ur carb that will make a h*ll of a diff on the ruff ride jettin is good when u are goin from sea level to the rocky f*ckin mt. and yes his quad only did about 65 or so with that pipe on there and when i said 70-72 i ment the kfx so really dont f*ckin make it sound like u know what ur talkin about when u are wrong
not to be mean or anythang but dont diss people just cause u think u know everythag about quads
#99
Originally posted by: LTZevil400
You don't always have to jet just because you put a pipe on, big misconception!! More times then not jetting isn't needed. It's when you get more air in that you have to rejet, no ifs, ands or buts.........
Originally posted by: D3athShad0w
*A dg pipe = **** and it would not get the warrior to 72 so no **** you won
*Of course he jetted it, he put a new pipe on... lol
07-15-2015 02:07 AM
