Yamaha wolverine power
Old Jan 10, 2005 | 04:59 PM
BigBaller's Avatar
Default Yamaha wolverine power
Hi, I own a 2001 yamaha wolverine. Recently ive been finding my self stuck on big ditches because I am going to slow. I am wondering if I can get any mod that will have more power so I can go over obstacles easier. I was looking at a tourque stuffer. Is that what I need?
Old Jan 10, 2005 | 05:02 PM
YamahaBlaster200's Avatar
what up big pimpin, u might wanna look at a pipe
Old Jan 10, 2005 | 05:07 PM
BigBaller's Avatar
yamaha blaster, I got a fmf megamax
Old Jan 10, 2005 | 05:09 PM
lol my bad i jus woke up
Old Jan 10, 2005 | 05:24 PM
BigBaller's Avatar
Hey, yamaha blaster, im thinking of getting a blaster. How fast can you hit on yours?
Old Jan 10, 2005 | 05:31 PM
jus gotta 240 kit didnt put in my sig yet, stock they do 58.. more or less... the quickest ive got mine up to is around 78
Old Jan 10, 2005 | 05:35 PM
NBake's Avatar
U did mess around with the sprockets right??
BigBaller, for some torq, try a high compression piston
Old Jan 10, 2005 | 05:39 PM
BigBaller's Avatar
Will a tourque stuffer give me that extra power? It says it gives 2 hp to the engine.
Old Jan 10, 2005 | 09:59 PM
trailcrawler's Avatar
hey bigballer.........the absolute most power gain I had was when i changed jet from stock(141.5) to a 155 main and drilled out the hole in the bottom of the slide in the carb slide is vaccume operated and is controled by a hole in the bottom. disassembled carb. remove needle out of slide look into inside of slide, to one side of needle hole you see a vacume hole drill it out. I wnt as big as housing wuold let...5/32", plus 1/8" on oposite side... slid jumps open with throttle!!!!! reassemble carb with needle clip in middle groove.(this is my combination,a deffinate seat of the pants increase feel) this was my last mod and most sunifficate!!!
greg74
Sep 10, 2019 03:03 PM
Gtsordo
Jul 22, 2015 01:27 PM
RedRancher
Jul 10, 2015 06:36 PM
Jul 7, 2015 11:00 PM
tweeder
Jul 5, 2015 01:57 PM
