Wolverine problems plz help!!!
Old Jan 10, 2005 | 09:32 PM
01wolverine01's Avatar
Default Wolverine problems plz help!!!
I have a 2001 wolverine and one day I went riding and and wrecked and the dash piece got snatched off and ever since it hasnt acted right I checked all the wires and everything, it wont start on its own the battery is fully charged... I tow start it and it will run as long as you hold the throttle but as soon as you let off the gas it dies and I checked to see if it had spark, sometimes it does sometimes it doesnt and sometimes its really weak anyone know what it might be?? thanks......
Old Jan 10, 2005 | 09:41 PM
trailcrawler's Avatar
check the wires to the ignition coil under the tank if one of the wires come loose, weak spark or if the coil is loose from the frame........ follow all wires down thruogh the frame that none of them got stretched broke inside covering or grounding to frame
Old Jan 10, 2005 | 09:54 PM
Thanks, ill check tomorrow..
Old Jan 16, 2005 | 11:14 PM
I finally got around to working on the wolvy, I took both front and rear plastic off and traced all the wires and none were stretched or broken or shorted out so I traced the hot wire from the ignition coil to the CDI and I cut the wire open right where it goes into the CDI and i spun it over and it wasnt hot so I checked the one on my Big Bear and it was so Im guessing that its my CDI im going to get a new one if I can find one, thanks for the help.........
Old Jan 17, 2005 | 12:11 AM
what year is the big bear? is it a 350 or 400 if 350 change cdi from big b to wolv and see ifit works.
Old Jan 17, 2005 | 07:05 PM
the big bear is a 01 and its a 400 I already tried to use it, its not the same, thanks anyways
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
