HP numbers for the Raptor?
Old Sep 19, 2000 | 10:12 AM
bash's Avatar
newblue,
Wow! With rear wheel hp as measured on the dyno nearing 50 hp, the crank horsepower must be somewhere over 60 hp! With the peak moving up to 8,000 rpm, it sounds like the power issue is all airflow related, both in and out. Also, I have noticed that stock jetting is on the lean side.
Old Sep 19, 2000 | 02:00 PM
ScoobyDFW's Avatar
NEWBLUEYAMAHA, Can you explain your HP numbers one more time? Are you saying 47HP at 4000RPM, then a drop to 42HP between 4000-8000RPM, then a peak to 47HP at 8000RPM? I don't think 47HP is possible at such a low RPM of 4000RPM. Please post the dyno charts so we can see the whole curves.
Old Sep 19, 2000 | 02:56 PM
86atc250r's Avatar
That sounded awfully fishy to me as well...
Old Sep 19, 2000 | 06:11 PM
NEWBLUEYAMAHA's Avatar
THIS IS ALL SECOND HAND INFORMATION. I WILL TRY TO GET CHARTS FROM RONNIE. BUT I NEED TO PUT TEN MORE HOURS ON MY RAPTOR BEFOR I EVEN THINK ABOUT PUTTING IT ON A DINO. THE WAY IT WAS DESCRIBED TO ME LEFT ME KINDA CONFUSED, I GUESS IT SHOWS FROM MY POST. IT SOUNDED TO ME LIKE THE GRAPH DROPPED BETWEEN 4000 AND 8000 R.P.M.
bmxatv10
Oct 14, 2022 06:23 PM
ReconBayou
Oct 16, 2019 02:24 AM
Johnny Mac
Aug 15, 2019 03:13 PM
black_thunder
Sep 22, 2015 07:59 PM
