Warrior Starting Problems........???????
Old Jan 17, 2005 | 10:49 AM
Skirider's Avatar
Default Warrior Starting Problems........???????
Picked up the Warrior on Sunday and it runs pretty good (other than the damned thing is so loud that I thought somebody had cracked the throttle on a short track dirt car!!)
Anyway...starting it this weekend (8 degrees) I obvously think "choke it" a bit....well if you choke it at all you get nothing. Leaving it open you get it to start but obviously it takes awhile to warm up.
I am going to pull the air box and clean the carb etc but would this be a symptom of being rich at idle or maybe something isn't working right?
Appreciate the Feedback!!
Old Jan 17, 2005 | 12:37 PM
BlackandRedWarrior's Avatar
Air Cooled Rider
Future Govenator of Kalifornia!
My guess is it's rich. My carb was dirty and I could cold start it w/o the choke. Cleaned the carb and when she first fired up it wouldn't run without the choke. The choke on the Warrior adds more fuel.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Jan 17, 2005 | 03:05 PM
stang671's Avatar
i have an 87 an i have to choke the crap out of her , then she floodes out and i have to take out the plug and dry it off reinstall it and then she fires up and runs fine, i think i need a new plug.
Old Jan 18, 2005 | 12:46 PM
Boxhead's Avatar
If it pops quite a bit try to richen it a step. The cold air is dense and probably making it run lean, especially if the filter still needs to be cleaned.
Old Jan 19, 2005 | 03:43 PM
Air Cooled Rider
Box is right, partially. Cold air (more dense in O2) can cause it to run lean.
A dirty filter will cause it to run rich (can't get enough O2 into the cylinder.)
Old Jan 20, 2005 | 10:20 AM
Skirider's Avatar
Well this thing has alot of all the problems guys!!
I basically stripped it of all it's body parts yesterday and just used some spray carb cleaner and it has already helped the problem some.
It is popping at times and the filter is dirty. Will be doing alot of work in it this weekend and I will have more to report. Appreciate the help!
ski
Old Jan 20, 2005 | 03:38 PM
Boxhead's Avatar
Might be a good idea to check every last nut and bolt on it as well. You never know what previous owners have done to it. It would be a good idea to change the oil, grease up the zerks, and check the bearings as well. A friend of mine bought a 400EX used and the fool that owned it before him installed the oil filter backwards, even though it clearly stated which side went outwards. Goes to show how stupid people are in this world...
Old Jan 20, 2005 | 03:50 PM
Skirider's Avatar
Box,
All of those are on the checklist for this weekend!! I believe the guy that had it before me was a complete mechanical moron....where I am just a semi-mechanical moron [img]i/expressions/face-icon-small-smile.gif[/img]
ski
Old Jan 20, 2005 | 07:31 PM
Air Cooled Rider
I'd recommend picking up a Clymer manual for the Warrior. Not sure what year you have, but the latest edition end in like -4 and goes through '03. I'm assuming '04 is the same, just different color. Cosmetically the Warrior didn't change much, but electrically and the carb changed over the years.
I'd pull your carb and clean it out good. Make sure all of the passages are clean and free flowing. Mine was really easy to take off. You're already most of the way there.
Also clean out the spark arrestor. I've stripped my bolt and can't get it out. But with you saying it's really loud, either they have an aftermarket exhaust, or pulled the spark arrestor anyways.
Defintaly clean that air filter.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
