blaster wont idle...
Old Jan 27, 2005 | 02:10 AM
ImmaculatePro's Avatar
Default blaster wont idle...
exactly as title...for some time now my 2003 blaster will not idle...i tried adjusting it on the carb but i dont kno if im turning the right screw....can anyone show me how to fix this...i dont have the manual because i dont kno wat i did with it lol....but an help is appreciated because it wont stay running without revving it....it sux....thanks in advance
Old Jan 27, 2005 | 02:16 AM
2FAST4U69's Avatar
Im not to sure about blasters on all the carb adjustments, but I would try cleaning the carb, and possibly replace reeds??? just my 2 cents
Old Jan 27, 2005 | 02:24 AM
hey wat do u recomend me using to clean the carb
Old Jan 27, 2005 | 02:29 AM
2FAST4U69's Avatar
I clean mine by soaking it in parts dip over night, u could take it apart though if u know what ur doing.. I had problems like that on my rm, and my carb needed cleaned and my reeds were sticking.
Old Jan 27, 2005 | 09:59 AM
Shav0's Avatar
On top of your carb is what is called the TORS system. On top of that unit there is the idle ajestment screw. You were probably turning the air screw which dosnt really set the idle. In oder to set the idle you need to adjust the screw on top of the TORS unit on top of your carb. If you take the seat off you should be able to look down ontop of this unit and see the screw. Its a big screw that you can turn with a flathead screw driver. You can see it under the seat on the left hand side, just below the airbox snorkle.
Old Jan 27, 2005 | 09:38 PM
garrett5462's Avatar
turn the screw shav0 is talking about clockwise, that will rise the idle
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
