OPINION ON MY WARRIOR
Old Jan 28, 2005 | 11:11 PM
warriorboy22's Avatar
Default OPINION ON MY WARRIOR
I HAVE A 2003 WARRIOR WITH JET KIT, POWERCORE4 SLIPON, AND MAXXIS RAZR FRONT AND REAR TIRES, WHAT SHOULD I DO NEXT
Old Jan 29, 2005 | 12:17 AM
FdaDOT200's Avatar
web cam
Old Jan 29, 2005 | 12:20 AM
WHAT DOES A WEB CAM DO
Old Jan 29, 2005 | 01:42 AM
VelociRaptor350's Avatar
Its a camshaft, it controls the opening and closing of the valves in your motor, check out this site, it'll help you out.
http://warriorcentral.proboards42.com/index.cgi
Old Jan 29, 2005 | 01:51 PM
Gwinnwarrior's Avatar
barnett clutch kit...about 100 bucks, worth every cent.
K & N filter too....
Old Jan 29, 2005 | 02:41 PM
strubby's Avatar
I flipped the rear and front OEM wheels, and added 1.5" wheel spacers up front. It handles awesomely now. If you don't do big MX jumps, go for it. It makes a huge difference and I love it. Oh, and I'm using that setup with the same tires, check my gallery pics if you're interested.
Old Jan 29, 2005 | 04:09 PM
Boxhead's Avatar
A good aftermarket carb (one with a pumpshot) or a cdi make a hell of a difference on the warrior, I would recommend both before digging into the engine. Those will give one hell of a punch that you can have fun with until you save enough for the engine mods. Cutting the mudguards and a oil cooler are also simple mods you can do in the meantime that aren't that expensive. When you do dig in the engine the web cam I would recommend also, I've only seen one on a 400EX so far, but that was only a all around cam, and they make a race style cam for the warrior. That all around one was a mean motherf*cker on the EX. Oh yeah, a set of tougher brakes and a self cleaning rotor could come in handy on the back end, since the stockers will probably score and start crumbling soon on you, depending what you ride in. The front rotors are excellent though, and they shouldn't be a problem. Being able to stop quick is a good thing when you'll be starting to go much faster.
Old Jan 29, 2005 | 06:27 PM
Banshee392's Avatar
CAM!!!!
Robinhood
Dec 26, 2015 10:28 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
rgjackson
Sep 17, 2015 11:21 AM
