Warrior Help!
Old Feb 3, 2005 | 10:08 PM
Joesmoe350's Avatar
Default Warrior Help!
I have an 01 warrior and all it does when I hit the sart button is make a buzzzing noise of the electric motor going but wont fire up. Anyone have any suggestions on the problem.
Old Feb 3, 2005 | 10:15 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
try to bump start it... also i think buzzing is dead battery?
Old Feb 3, 2005 | 10:18 PM
2phast4u's Avatar
im havin the same exact problem right now last time it happend i replaced the starter solinod under rear fender on the left dats wats buzzing right? well i replaced that and it worked for a while them went again so i havfta look over all my wiring but yeah itf u want it fixed temporarily just replace the battery and starter solinod i think it was only lik $12 and the battery was about the $20 i think maybe more but it should fix it also try getting electrical cleaner that dryes out the wires incase ne water got in there
Old Feb 3, 2005 | 10:22 PM
Joesmoe350's Avatar
the lights work but the buzzing is also coming from the solinod so it might be that.
Old Feb 3, 2005 | 10:28 PM
2phast4u's Avatar
yep exact thing mines do just replace the solinod if that goes again check wiring
Old Feb 3, 2005 | 11:22 PM
WarriorDude69's Avatar
Hey guys, my warrior does something similar every now and again. If I havn't started it in a while I just get a buzzing when I hit the starter button. It turned out a bunch of mud and crud got into the starter switch. So with the dirty contacts not enough current was getting to the starter solinoid to activate it. I just take it apart and clean it all up and all is good.
Old Feb 4, 2005 | 04:38 PM
2phast4u's Avatar
i tried that i took the solinod off scrubed the wires w/ wire brush clean the solinod completely what else should i do
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
