Raptor Spark plugs, airbox, etc.
Old 09-18-2000, 08:21 PM
YaMaRaPtoR's Avatar
Ok, I have some thoughts I would like some input on.
First those of you who removed the spark arrestor,
Did you check your jetting, and adjust the airscrews? and was it a noticeable increase in power?
Second those of you who took out the airbox restriction like I did, Did you adjust the carbs or anything? I felt a small increase in power, but did not have to adjust anything.
Third Has anyone went to a hotter plug yet?
If so what where the results?
Fourth I havent really looked a the tops of the carbs closely, So dont make fun of me when I ask, Is there a Balance Tube like on a Banshee, that could benefit from the addition of a Boost Bottle?
Old 09-18-2000, 08:37 PM
shollz's Avatar
I cut out the plastic piece, and it made a little difference. I took the spark arrester out and it made a noticeable difference from third gear on up, the power justs hits and keeps on pulling. The plug looks good, i think it was jetted to rich form the dealer.
Old 09-19-2000, 11:38 AM
Bandit99's Avatar
How did you end up pulling your spark arrestor? I tool of the chrome cover, then the bolt that goes up through the bottom of the spark arrestor, but it still wouldn't budge. I even tried hitting it out with a chisel around the flare where it joins up with the silencer, but no go. Any suggestions?
Old 09-19-2000, 12:18 PM
shollz's Avatar
I didn't even take off the chrome end cap. Just remove the bottom bolt, then get a pair of pliers and a rag. I put the rag in the jaws of the pliers so i didn't mess the finish up on the spark arrester. Just grab the top lip and twist back and forth while pulling at the same time and it will come out. Hope this helps
Old 09-19-2000, 12:23 PM
Bandit99's Avatar
So, after you took it out, how does it sound?
And have you checked to see how your plug is burning since you did it??
Bob Maurice
1) Engine problems..
07-14-2015 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
07-12-2015 07:22 PM
Unzzy66
07-11-2015 10:01 PM
Dirtbikemike1
07-09-2015 01:27 AM
D-Hagz
07-04-2015 02:19 AM
Quick Reply: Raptor Spark plugs, airbox, etc.
