How to take baffle out
Old Feb 8, 2005 | 07:03 PM
Warrior02man's Avatar
Default How to take baffle out
How do I take my baffle out? is it easy?
Old Feb 8, 2005 | 07:04 PM
86LT250RFatty's Avatar
Their is one bolt holding it in the muffler. take the endcap off, take the screew out, and PULL!
Old Feb 8, 2005 | 07:11 PM
Madwolverine's Avatar
Spray it with some wd 40 before you attempt to get it out. Take your time or you will bend it up.
Old Feb 8, 2005 | 08:46 PM
the warrior exhaust is rounded.. i just went outside to look at it and i saw two layers of metal. One which was the muffler flame, and then another layer on the inside, with a very tiny lip coming out the tip. Is this the baffle, the thing inside? Is it a tube.. or does it take up the entire mufffler.. cuz if it does.. then there is no way it is coming out. O yeah, btw, is the screw at the end the muffler, near the tip? cuz if it is.. my screw ain't there.. just a hole where a screw LOOKS like it should go.
thx.
Old Feb 8, 2005 | 09:39 PM
the baffle is about 6" long, their should be a small hole at the bottem of it. the baffle is like 3" wide, it will make a big opening in your muffler
Old Feb 8, 2005 | 10:33 PM
It is the "inside layer" After you pull it out there will be a large open hole which is the "muffler frame" as you put it.
Old Feb 8, 2005 | 10:41 PM
so.. i cna just pull it out right? just tug on it really hard with wd 40 and just pull right? nothign will brake and my muffler will be the same right?
Old Feb 8, 2005 | 11:30 PM
YamahaRyder4Lyfe's Avatar
Grr...i took my baffle out on my raptor...really loud, i like though[img]i/expressions/face-icon-small-smile.gif[/img] I had to heat mine up with a torch though, to get it out, it was in there GOOD, and now its all bent up, so i couldn't put it back in if i wanted, heh, to bad
Old Feb 8, 2005 | 11:54 PM
Yes but take your time. One guy on here had a great idea. He used a dent puller. Either way it just pulls out.
Jason Poulin
Sep 20, 2015 02:49 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Huntingdeer
Aug 23, 2015 12:06 AM
raceware
Jul 30, 2015 06:59 AM
cSchwartz
Jul 12, 2015 07:42 PM
