blaster still not running
Old Feb 16, 2005 | 04:55 PM
nickynauw's Avatar
Default blaster still not running
i have an 03' blaster with a alien pipe and k&n filter and holeshot tires anyway i was ridin it around and it just bogged down and shut off. i got it home and checked out my spark plug checked my piston cleaned my carb and cleaned my filter but it still dont run can anyone give me some sugestions please
Old Feb 16, 2005 | 05:00 PM
NBake's Avatar
what did ur spark plug look like when u took it out? did u try a new plug?
Old Feb 16, 2005 | 05:11 PM
nickynauw's Avatar
yea new spark plug
Old Feb 16, 2005 | 05:23 PM
NBake's Avatar
what did ur plug look like when u took it out?as of right now, all i can think of is try new gas and check ur spark.
Old Feb 16, 2005 | 06:20 PM
candyman72's Avatar
is there a block in your fuel line ??? filter???
Old Feb 16, 2005 | 07:20 PM
Fastblasterboy's Avatar
Is your gas turned off?
Old Feb 16, 2005 | 08:18 PM
nickynauw's Avatar
no the gas wasnt turned off, the plug was fouled when i took it out and i am putting new gas in tommarow
Old Feb 16, 2005 | 08:33 PM
garrett5462's Avatar
reeds maybe?
Old Feb 16, 2005 | 10:49 PM
blaster2002004's Avatar
When you tried to kick start it again did it have compression?? and when you checked the top end did you see any small peices of alluminum? Cause if you dont have any compression its more then likely a piston blown.. Other then that see if the reeds are all good and you might wanna see if your getting any air leaks anywhere near the carb.
Old Feb 16, 2005 | 11:10 PM
Shav0's Avatar
Could be the crank seal on the clutch side. When it goes it draws tranny oil in because the crankcase creats a vacuum. It would cause a problem similar to what you are experiencing, just imagine 10w30 getting in on the spark plug, it fouls quicker then you can change them. Pull the clutch cover off and check out the seal behind the primary drive gear that runs on the clutch, you should be able to see if anything was wrong with it.
Frisky2050
Apr 9, 2020 11:19 AM
tpd270
Jul 5, 2015 10:38 PM
tpd270
Jul 1, 2015 08:18 AM
Shooterj2003
Jun 21, 2015 09:02 PM
blazer316
Feb 27, 2001 01:28 PM
