How do i remove warrior stator cover
Old Feb 19, 2005 | 11:53 PM
FoxForma's Avatar
Default How do i remove warrior stator cover
To make a long story short I thought I blew my gears out on my warrior but it was something very simple that i overlooked. Everything is running fine but after I started to take some things apart, once i put them back together I noticed oil was leaking out of my stator cover side on the bottom. When i was trying to remove it, it would only come out about a half inch then felt like it was being pulled back in by a spring or something. I have to get this piece off because the the gasket is messed up and it will not seal properly causing the slow leak. Am I missing something with taking this thing apart. It there some other step i need to do to get it apart, i dont want to pry on it and cause more damage so any help would be greatly appreciated.
Old Feb 20, 2005 | 12:23 AM
toy4rox's Avatar
are you tolking about the left side cover ? if so the stater is magnetic and the springing you are feeling is the magnitisom if i remember correctly. i went to the shop to look at my book but i forgot its not here but i'm pritty sure just remove the bolts and pull off.i don't remember oil being in there. the other side { clutch side } has oil though.
Old Feb 20, 2005 | 12:27 AM
FoxForma's Avatar
That is the side I am talking about, so you think it is just the magnetic energy holding it together? I didn't think oil should of been in there also but apparently there is. The quad doesn;t smoke or anything so I assumed that is ok. SO should I just pry it apart then? Hope someone can clear this up so i dont really mess things up. Thanks
Old Feb 20, 2005 | 12:32 AM
toy4rox's Avatar
i'm sory my book is at the shop with my moter right now but i just took my moter apart not to long ago and don't rememberany thing that would hold it in.but i'm not absolutly sure.
Old Feb 20, 2005 | 12:38 AM
FoxForma's Avatar
ok thanks, I guess we'll see what happens
Old Feb 20, 2005 | 02:21 AM
FoxForma's Avatar
I figured it out
Old Feb 20, 2005 | 03:55 PM
jaggers2e42's Avatar
yeah it's just got a strong magnet i had a small leak on mine right at the bottom put on a new gasket and would you know i cracked the cover when i put it back on[img]i/expressions/face-icon-small-frown.gif[/img] but now it back on the trails just be carful when putting it back on cause they aint made out of much!
Old Feb 20, 2005 | 05:25 PM
FoxForma's Avatar
Actually the cover is what i was having a problem with, had nothing to do with the magnet. I had to grip the bolt on the outside then use a socket to turn it off then the opposite to put it back in. All better now.
Old Feb 20, 2005 | 09:38 PM
oh,yeah sometimes it helps to get all the bolts out[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Reactant
Mar 30, 2022 02:08 AM
manuelrivera
Aug 8, 2015 04:34 PM
Ashley S
Jul 31, 2015 09:46 AM
Captjay
Jul 23, 2015 12:33 PM
