banshee runs good until i give full throttle whats causing it?
Old Feb 21, 2005 | 02:05 PM
NastyNate03's Avatar
Default banshee runs good until i give full throttle whats causing it?
yea it is cold here around 40 degrees when i ride or so it should get warmer here shortly
Old Feb 21, 2005 | 02:07 PM
86LT250RFatty's Avatar
it could be lean or rich, cant tell unless you ride it. when you go full throttle, does alot of smoke come out the exhaust??? if so, your too rich... get 2 sizes bigger and smaller and see what worKs beSt.
Old Feb 21, 2005 | 02:10 PM
DLRPLATE's Avatar
If You want to know if its too lean pull the choke out at wide open throttle if it speeds up its lean if it gets worse its rich.
Steven Bandemer
Jun 9, 2015 08:50 PM
RaymondT
May 26, 2015 08:14 PM
Smokinthebear
May 7, 2000 08:01 PM
undecided
Sep 7, 1999 05:42 PM
