How to make warrior haul but
[img]i/expressions/face-icon-small-disgusted.gif[/img] I have a 2000 warrior and have already installed kn filter,jetted,white brothers exhaust. I would like to know what I should do next I would like to make a huge improvement in performance. Is their anyone out there that has did any engine mods and was it worth it.
The stock comp. is 9.3, so a 10.75 or 12 comp piston should offer a very good gain over stock. As for cams get a web race cam so the thing will transfer the excess bottom end and put it to the top and upper mids. Ignition, carb, valve springs, and port n polish are good ideas also. An aftermarket clutch such as a honda cr style ez pull bearing one will help you get through the gears quite a bit faster, there is 30 percent less lever pull.
