Help for a friend
Old Feb 28, 2005 | 10:51 PM
warrior007's Avatar
Default Help for a friend
The right side comes off, no clip or anything. Use a 2 x 4 and a sledge, it helps to use another 2 x 4 to brace the swingarm against a wall to absorb some of the force from the swingarm and frame. Heat works on the right side carrier peice to expand it. Make sure to take the adjustment bolts all the way out, slide the carrier back as much as you can, this will leave a good amount of room to hit it using the 2x4 and sledge, work the bottom and top equally.
Once you get the right side off it just comes out of the left. Do yourself a favor and sand down the pieces so they fit better for next time. To reassemble brace it the other way and tap it on a little, then let the bolts that go through it do the work on pulling it back on.
The carrier is shouldered so the bearings will bottom out and not go in any further, make sure he leaves the spacer in or you will tighten the axle on the inner races and side load the bearing.
Old Feb 28, 2005 | 11:43 PM
ridinsmooth's Avatar
that what you get for getting a craptor you need to tell your friend to get a ds like yours LOL
Old Mar 1, 2005 | 12:23 AM
bl4cksh337's Avatar
Originally posted by: mudnuri
My buddy has an 03 Craptor. He replaced the rear axle bearings. When it went back together there was a little gap on the left side. He rode it and log story short it wobbles now. He took the axle out but can't get the carrier out. I am hearing this over the phone and can't actually see it to tell you. So this is all I've got.
How do you get the carrier out?
hey why dont you just go f youself and take your craptor comment with you and take ridinsmooth with you. And maybe if you were smart you wouldn't talk crap in a yamaha section if you really wanted help. I mean im getting my dads 660 and i'd prefer it over a 650P.O.S. going bankrupt, low rate company bombardier anyday.
Old Mar 1, 2005 | 12:25 AM
bl4cksh337's Avatar
sorry ridingsmooth if you were being sarcastic.
fredrikrosen
Sep 28, 2015 09:58 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
WilliamBos
Sep 22, 2015 04:07 PM
awer1968
Sep 8, 2015 11:02 AM
