squeaky rear shock on raptor
Originally posted by: BigDylan
yeah thats exactly what i ended up doing friday night my buddy had some liy=thium grease in an aerosol can and i loosened it and blasted it and when i put it back tight again the squeek was gone
#18
I had the same problem when I had my raptor, I took out and completely cleaned both rear shock bolts and bushings, then lubed them with high temp red grease and the problem was gone, I also did the same on the front shocks, they were starting to sqeak as well.
#19
Originally posted by: INSeaRChOFDUNez
Try Losening the nut 1/4 turn, and post again if it continues. i had teh same problem . i added antiseize, regualr grease wd-4o and nothign works. the only way it worked for me was to loosen the nut 1/4 turn and it never did it again. btw the nut doesnt loosen either just incase add a drop of loc-tite.
#20
