???Ok...whats the problem???
Old Mar 12, 2005 | 06:44 PM
BaD04WarrioR's Avatar
Default ???Ok...whats the problem???
I thought my battery was shot. I got a new one and put it in. When I go to start it it has a hard time cranking. Like it hardly wants to crank at all. What. needs to be fixed and how can I check it or do I have to just buy the part to determine what it is. Its an 04 warrior by the way.
Old Mar 12, 2005 | 06:50 PM
garrett5462's Avatar
the starter could need to be replaced.
Old Mar 12, 2005 | 06:52 PM
hondabuster's Avatar
Could be alot of things.
Does it just crank over slower than it should? Will it eventually start? Is it better when the motor is hot or cold?
How did the battery connections look, when you put the new battery in? shiney and tight?
Old Mar 12, 2005 | 07:00 PM
if tyhe engines really cold, try putting it in a garage ( heated) or find some way to heat up the engine.
Old Mar 12, 2005 | 07:03 PM
I took the battery out and hooked it strait up to a charger w/ 225 amps and it was cranking a little better but still didnt want to start. Ive never had this problem with it being in my garage plus the other day it was in heat all day and still wouldnt start. Its about 2 years old. How much is a starter and where can I find one
Old Mar 12, 2005 | 07:08 PM
you can get starters here ... warrior starter page
Old Mar 12, 2005 | 07:09 PM
or try this one. another page.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
