Changing my warrior starter
I think my starter is going bad on my warrior. I was wondering if its a project to put a new one on and where exactly the starter is located. The atv isnt here otherwiser Id go outside and look to find it. Any help would be appreciated
Yeah I already have a new one on the way. 130 shipped to my door next day air. Where exactly is the starter located. And if I took my starter out now what would happen If I needed to push start it. Would it still work. Or should I not mess with it when the starter is out.
Do NOT start your warrior (push or otherwise) with the starter removed. The gear for the starting motor goes onto the flywheel which is directly in the crank case oil. If you start up the bike with the starter removed, it will spray all your oil out of the motor.
As for where it's located, it's right at the front of the engine. Little cylinder on the front of the engine case. It's removed from the right (rear brake) side of the quad and is really really really easy to do.
