Oil problem (wrong oil?)
Old Mar 13, 2005 | 02:54 PM
pietrangolare's Avatar
Default Oil problem (wrong oil?)
Hey,
Ok. now i know this might sound like a dumb question, however i just bought a 94' Yamaha Blaster. I purchased oil, not knowing what kind its called "Super Tech-Outboard 2-cycle engine oil" i put it in already is it the wrong kind of oil and if so should i just change the oil and put the right stuff in? thanks
Old Mar 14, 2005 | 08:25 PM
Blaster96's Avatar
I do not know the specs on this kind of oil.
I would suggest buying the proper oil. The clutch disk's could start to slip with the wrong oil, causing premature wear.
Old Mar 14, 2005 | 08:59 PM
JLsparky7's Avatar
you talkin for the gear box or oil tank for the motor?
Old Mar 14, 2005 | 09:04 PM
cerv's Avatar
Old Mar 18, 2005 | 07:24 PM
LightinUpABomb's Avatar
ok.. Listen this is my other name ... this is what happened i bought the oil and i put it in the injector tank. thanks
Old Mar 18, 2005 | 08:18 PM
JLsparky7's Avatar
my friend and i use amsoil 2 stroke oil. It says "for v twin engines" on the front it works flawless and smells great when it burns. Little expensive but you dont use up that much on blasters. Id reccomend it for anyone with a 2stroke machine.
Old Mar 18, 2005 | 09:16 PM
Fastblasterboy's Avatar
I sugest go and buying Klotz(the blue bottle) they are 8.99 a quart at my local shop. It smells great when you are riding.On the oil tank there is a couple bolts that you gotta remove, there is a sensor on the top of the tank, unplug the wires, then remove the tank out and dispose of the oil properly, then Just take off the cover on the righ side of the motor, Youll see a little pump with a line running from the tank, there is a clip on the hose holding it to the pump, slide that back the pull the hose off, get an old town and set it at the end of the line, go to the other end and blow the old oil out. Once the tank it empty, install the tank , bolt it back in, and plug the hose back into the pump. Re connect the sensor, Fill the tank up with the new Klotz, then go back to the pump and pull off the hose again to make sure the oil is running out, if not you might have to siphen the the oil, once it begins to flow plug it back in to the pump. When you start it up make sure you let it idle for a minute to make sure you see the smoke coming out of the silencer.
I once bought some kawisaki two stroke oil and it plugged up the pump and the motor over heated and quit running. It was way too thick for the yamaha blaster so i suggest getting Klotz.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 18, 2005 | 09:25 PM
JLsparky7's Avatar
I heard klotz is good stuff, i also heard amsoil is just as good but cheaper. I deffinitly like the smell of klotz more. Amsoil accually smells a little like chocolate cake to me. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 18, 2005 | 09:27 PM
Klotz has a sweet smell to it. When you buy a new bottle open it and smell it. Smells sweet
Old Mar 18, 2005 | 09:28 PM
That is funny "chocolate cake" [img]i/expressions/face-icon-small-smile.gif[/img]
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
