advice please.... banshee bogging out.
Old Mar 18, 2005 | 05:52 PM
ImASissy's Avatar
Default advice please.... banshee bogging out.
ok. my banshee was running great, then I put the two k&n filters on. i then rejetted it... 2 sizes up. ( i had 270's on it, then rejetted with 290's). okay, so i took it out and it screamed like a rape victim. now, one week later, I changed the spark plugs and drained coolant and refilled. now it bogs out when i have full throttle. What the heck happened? the ONLY thing I could come up with was that my jets are either too rich or to lean, but I rode on those same jets ONE week ago and it ran GREAT. Any advice anyone? opinions?
Old Mar 18, 2005 | 08:12 PM
NBake's Avatar
did the weather change at all?
Old Mar 18, 2005 | 08:20 PM
ImASissy's Avatar
maybe a few degrees
Old Mar 18, 2005 | 10:09 PM
NBake's Avatar
u could do a plug check to see if its rich or lean
Old Mar 18, 2005 | 10:31 PM
TrailBlazerguy250's Avatar
mine dose it everyonce in a while
Old Mar 19, 2005 | 08:06 PM
ImASissy's Avatar
ok. i just too out my old plugs. how do i determine if it is rich or lean?
Old Mar 19, 2005 | 10:52 PM
redwingsrule05's Avatar
stupid two-stoke for you
Old Mar 20, 2005 | 12:35 AM
ImASissy's Avatar
piece of crap. pulling stupid crap. i am so pisssed. i just want to sell the dang thing
Old Mar 20, 2005 | 01:36 AM
DNS's Avatar
DNS
put in the other plugs or check if they are the same plugs even.
Old Mar 20, 2005 | 01:48 AM
DNS's Avatar
DNS
if the tip of the plug is white then its too lean and it wont bog down if its lean and if its and if its rich then the plug will be black and wet. it will bog down if thats the case. you gotta check em right after you run it. dont run the machine and slow down to a stop. to get a true reading of whats happening with the mixture, run the bike for about a mile at a litte over three quarter throttle so that your main jets kick in and then pull in the clutch shut the bike off and let it coast to a stop and dont use the brakes if at all possible. I read this on the mikuni website because i was having a similar problem with my snowmobile and yamaha has mikuni carbs on all there machines so i hope this will help. post a forum after you've read this and let me know how it went.
