Crossthreaded screw that holds the airfilter on......cant get it off
i know... the plastic cone that the bolt goes into inside of the air filter has a nut inside of it. the plastic holding the nut in place probably broke or stripped because u could of put the bolt on to tight. so, it is just spinning the nut inside the plastic, the same thing happened to me. i had to use a pair of cutters to cut apart the plastic and get to the nut inside. i hope u can figure out my explanation.[img]i/expressions/face-icon-small-smile.gif[/img]
Originally posted by: Fastblasterboy
There isnt a nut on the other side. The bolt screws into a little plastic thing that looks like a triangular cone and the plastic part is threaded. Maby there is one on the bottom of the plastic deal but if you think about it the filter is prety tall and that doesnt leave n e room for it to go down through the little plastic thing at the bottom, that is why it is a cone shape that sticks up. ( at least i think)
Originally posted by: yrrej
how am i sopose tog rab it and pull it with plyers........it is screwed all the way in there is no space
#15
Oct 10, 2015 10:20 AM
