New Craycraft 730 ride report
King- Find you a good 1/8 mile drag strip and have fun changing back and forth thru the curves. It has been a while since i have played with the stock dyna settings but 1 of them #3 i think will get you moving down the track faster but will run out of steam around 400-450 feet compared to a different setting.
Best bet is to run the Craycraft setting. It has been designed to destroy all the other builders best[img]i/expressions/face-icon-small-smile.gif[/img]
I flipped through the different curves while playing around this evening. Curve three definitely seems to have way better accel in the lower gears 2-4, but it lacks up top bigtime, just as 14 said. I couldnt tell a big difference in the others, but i still have my stock swingarm and keeping the front down in fifth is a problem. My extended should be here in a couple weeks. Im going to run a trinity built 250r this weekend, not sure what he has done to it. Havent seen it run but Ive heard its fast. Guess it will be the raps first test. Do you guys recommend the 3rd curve? It wont be at a track, so Id say it will be approx a 1/8th mile race.
