Wolverine ISSUES! WON"T Idle!!!! Please help
Old Apr 1, 2005 | 02:19 PM
big4x4's Avatar
Default Wolverine WON"T Idle!!!! Please help
Well, I decided to ride my wolverine again (it has been over 6 months just sitting!). I changed the battery (old one died) and tried to start it up. I choke it and it eventually comes to life. I noticved that it idled pretty rough with the choke on so I let it warm up for about 5 minutes before cutting the choke. Right when I put the choke in it DIED! I do not know why! The only way to start it now is to choke it. Also, is it bad to leave the choke open but adjust the idle screw so it will idle normally? That seems like the only way for it to idle normally. I have also noticed that when I shake the bike while driving it will start to sputter. Any insight? Thank you [img]i/expressions/face-icon-small-smile.gif[/img]
Edit- WHen I try to start it up without the choke, it seems as if there was a "plinking" sound coming from the engine. What could that be? I checked the oil levels and it seemed fine.
Old Apr 1, 2005 | 03:06 PM
bberck's Avatar
Default Wolverine ISSUES! WON"T Idle!!!! Please help
If it sat for six months you probally need to drain the gas and clean the carb.
Old Apr 1, 2005 | 03:19 PM
BigBearFX's Avatar
dido
Old Apr 1, 2005 | 05:12 PM
big4x4's Avatar
Since I was taking apart my wolverine I just decided to take it all apart to clean it thoroughly. Sorry for the noob question, but what should I do to clean the carb? Thank you for your help [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 1, 2005 | 08:42 PM
Six2notScaredofU's Avatar
Go get some carb Cleaner from your local parts store. remove your carbs and the bowl spray out the carb and make sure you spray out the needle valve ect.[img]i/expressions/face-icon-small-smile.gif[/img]
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
