Assume It Is A Stock Banshee: What does 10:1 -- 15:1 -- 20:1 -- 24:1 -- 32:1 -- 40:1 -- 50:1 -- 60:1 gas:oil mix ratio
Old Apr 2, 2005 | 11:56 PM
ehlitdew's Avatar
Default Assume It Is A Stock Banshee: What does 10:1 -- 15:1 -- 20:1 -- 24:1 -- 32:1 -- 40:1 -- 50:1 -- 60:1 gas:oil mix ratio
-- 10:1
-- 15:1
-- 20:1
-- 24:1
-- 32:1
-- 40:1
-- 50:1
-- 60:1
gas[img]i/expressions/face-icon-small-blush.gif[/img]il mix ratio
do your banshee performance wise and reliability wise?
Old Apr 3, 2005 | 12:16 AM
maddog56's Avatar
The ratio you use is going to be based mainly upon the oil you use and the state of tune of your bike.
Old Apr 3, 2005 | 12:54 AM
TRLYFZ450's Avatar
Yamaha recommends 32 to 1. I ran MC1 at 40 to 1 with no troubles.
Old Apr 3, 2005 | 01:40 AM
JakalWarrior's Avatar
Less oil more power smaller jets. More oil more lubrication bigger jets. If you change ratios though you have to change your jetting. Also not good to use a rating far from what the oil reccomends. I hear people running 60:1 and 80:1 all the time but id never do that to my motor :/ 32:1 for me.
Old Apr 3, 2005 | 03:33 AM
TrailBlazerguy250's Avatar
i run a 32:1 and a 342 main jet
Old Apr 3, 2005 | 04:28 AM
DeuceRooster's Avatar
I run 32:1 Klotz R50 bone stock machine.
Old Apr 3, 2005 | 05:10 AM
i run klotz and amsoil
Old Apr 3, 2005 | 05:30 AM
NastyNate03's Avatar
i run my banshee on the stock ratio of 24.1 and use castrol or yamalube
Old Apr 3, 2005 | 08:24 AM
2fun's Avatar
As stated, the type and quality of oil should determine the ratio.
I have used Amsoil (fully synthetic) per their recommendations for years at 50:1
I also have used Golden spectro (semi-synthetic) at 40:1 for years.
Others recommend 32:1, and so on.
The main thing is to be sure you are jetted correctly. A lean motor will sieze a lot faster than a motor that is running slightly less oil in the pre-mix.
Old Apr 3, 2005 | 04:44 PM
homdaddy's Avatar
i run my highly modded polaris's at 80- 1 amsoil and they look like they have never been ran. inside after 2years. and the same for my turbo n20 snowmobile
