Winch information!
Old Sep 29, 2000 | 06:40 PM
Mork's Avatar
I recently purchased a 99 BB 4*4 equipped with a T1500 Superwinch. It came with a handlebar mounted rocker controll switch which didn't work. I removed the switch and took it apart and found it to be a very cheaply made unit. The case for it was made of a soft plastic that warped when the switch was used. This caused the bottom of the swich to pop out of place. My question is what should I replace it with? Is the rotary type switch more durable? Are they water proof? Or should In replace it with another new rocker switch. Any opinions appreciated!
Old Sep 29, 2000 | 06:46 PM
ETXLR8's Avatar
NO! I WOULD'NT GO BACK WITH THE ROCKER SWITCH I'VE REPLACED MINE THREE TIMES. I FINALLY REPLACED IT WITH A HEAVY DUTY ROCKER SWICTH FROM WHERE I WORK. IF I WERE YOU I'D GO WITH THE ROTARY TYPE OR SOMETHING BESIDE THAT YELLOW PIECE OF CRAP!
Old Sep 29, 2000 | 08:56 PM
Guest
Guest
Posts: n/a
If you have problem with a Superwinch product, I recommend you contact their customer service department, jack@superwinch.com
Tree Farmer
Old Sep 30, 2000 | 11:49 PM
Mudrunner5's Avatar
Get a Warn switch.
Old Oct 4, 2000 | 02:21 PM
KodiakDAT's Avatar
I too have the T1500 Superwinch.
If you contact superwinch they will send you and replacement switch with cover for top and bottom of the swich.
Old Oct 4, 2000 | 03:53 PM
Mork's Avatar
Thanks for the info people! I have contacted Superwinch and like KodiakDAT stated, they are sending me a new switch assembly! Again, thanks for the help!
Old Oct 4, 2000 | 04:36 PM
Harold's Avatar
I perfer the rotary switch, it's bulletproof!!!!
Old Oct 4, 2000 | 10:23 PM
14mins's Avatar
I got a Northern Tool and Equipment Co. catalog in the mail,they are selling Superwinch model t1500 for 129.99 and model t2000 for 189.99. Is this a good deal. They also sell the mounting kits. How often do you use your winch? Their phone number is 1-800-533-5545.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Sassinm1
Sep 30, 2015 04:23 AM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
