Banshee backfires
Old Apr 15, 2005 | 11:41 AM
AlkyBurninX's Avatar
Default Banshee backfires
Originally posted by: RDZ350
Hey AlkyburninX could you tell much difference when you switched pipes?
Yep, I can't hook this b!tch up now. 5th gear its still blowing the tires off. The shearers come on so strong and suddenly that it is almost unrideable. The loose 2 HP to CPI through the mid, but pull a lot harder and farther than CPI. I actually can't give all the credit for the new found power to the shearers. I have switched cylinders and carbs since I last raced it.
Old Apr 25, 2005 | 11:32 PM
barrons's Avatar
i have a 96 yamaha banshee and only 1 cylinder is fireing after the tope end has just been rebuilt cylinder was firing then just cut out on me while breaking in the engine(wasn't beating on it).....sometimes if i rev the bike up the cylinder will fire again but only for about 2 or 3 seconds. i have changed the gas cleaned the carbs and sycro them too....just put new plugs in and if you rev it up high now you don't feel anything coming out of that exhaust....any advice on what could be the problem??????
Old Apr 26, 2005 | 10:34 AM
Barrons, is your bike hard to start?
There is a 2.5-3" long black tube that connects the carbs. It goes in front of the slides, just above the bore. Many people forget to put this tube back in after having the carbs off.
Old Apr 26, 2005 | 07:40 PM
barrons's Avatar
it starts within like 3 or 4 kick usurally but i did replace the balance tube after the engine was rebuilt....forgot to mention also that the bike was backfiring some and sounded like a intermitate misifire from the left side before the cylinder went compleatly and i do still have spark
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
