27"s on Grizz
Old Apr 12, 2005 | 10:25 PM
travis13's Avatar
Default 27"s on Grizz
Will 27" Titan 589's fit on a stock grizz witout lift? Would 26"s be more efficient? Also what kind of stability gains will I see with new tires? Thanks
Old Apr 13, 2005 | 12:05 AM
BigScary's Avatar
I have 28" outlaws on my grizzly
fit fine without a lift........but I wouldn't recomend carying much weight with the 28 laws
28 589s clear perfectly with no lift.......my brother is running that setup.....
Old Apr 13, 2005 | 08:01 AM
Andy Bassham's Avatar
They will fit fine. You won't see any real stability gain unless you go with an aftermarket rim (which I believe every one of them have more offset than factory). With stock rims, all you would get would be maybe some extra width with 12" wide rear tires, and that wouldn't be enough to offset the fact that your quad is now higher off the ground. Aftermarket rims do wonders to the stability of a Grizzly.
Old Apr 13, 2005 | 08:26 PM
GrizzlyAdams01's Avatar
I have 27" ITP 589's with the ITP wheels on mine with no clearance problems. Check out my pictures...
1000gade
Sep 19, 2015 10:28 AM
toonces
Sep 5, 2015 01:14 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 23, 2015 02:21 PM
toonces
Jul 16, 2015 03:19 PM
