White spark plug?
Old Apr 19, 2005 | 10:03 AM
Rider1169's Avatar
Default White spark plug?
If your 5th gear wide open, and pull in the clutch and turn off the key, come to a stop and pull your plug and its white, is that a main jet problem? I know its not good to run lean, but wide open throttle is just a main jet problem correct? It runs fine throughout the rest of the RPM's, just top end, and when you let off at top RPM's it backfires and pops a little. Just looking for if the main jet is my problem?
Thanks----Rider1169
Old Apr 19, 2005 | 11:38 AM
yamahalltheway's Avatar
It is problay main jet i would say valve adjust but spark is clean if i were you i would have valve adjust and llok into main jet... good luck
Old Apr 19, 2005 | 11:49 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Got to agree. Check the valves first. If ok, I would go 1 step richer on the main and re check.
Old Apr 19, 2005 | 02:35 PM
CTATV's Avatar
could be valves but at WOT its definatly not the pilot jet.
Old Apr 19, 2005 | 03:16 PM
Rider1169's Avatar
Yea, i adjusted the valves, they were way out of spec, but are good now. It ran a lot better but is still way too lean, so im going to try the larger mains. Thanks--Rider1169
Big bousse
Sep 26, 2015 10:42 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Dirtbikemike1
10
Jul 12, 2015 07:22 PM
