best mx tires for a blaster
18-9.5-8 Turf tamer grooved for better traction and lighter weight. You can get them from Nac's ready to go. You will need bead locks if you want the most performance though. They will keep you from pulling the tire off the rim when you lower the pressure for more traction and a smoother ride. When I raced MX years ago, I ran between 4-6psi in the rear depending on how hard the track was.
CT250R
CT250R
